My new MCS 3249
Discussion in 'Tuners' started by Vintage Unit, Jan 10, 2018.
  1. Vintage Unit
    Vintage Unit New Member
    12
    After shopping around various local venues for a vintage tuner, I picked up this unit for $12 with an old (probably garbage) Technics single cassete deck on a local auction. All I knew was that it powers up. Did a bunch of reading on them to find out what I was getting into, and figured I'd probably have to replace/refurb a lot of buttons at the very least, and knew there was a chance I'd be the proud owner of a piece of junk. I knew it was a bit dinged up (but $12!) so wasn't expecting much.
    Good news! So far anyway. It not only powers up, it sounds better than anything I've had hooked up to my crappy old Sony speakers in years. The switches and buttons all seem to work, although I think the buttons are on the downhill slide and could stand some new foam perhaps. I got a tiny bit of crackle out of the balance and volume pots but it wasn't bad, and after working it back and forth it seems to have improved quite a bit. Maybe it will be fine. And sometimes it doesnt remember the presets after being shut off for just a few minutes, while other times it does. All in all, not bad for $12.
    slow_jazz likes this.
  2. slow_jazz
    slow_jazz Lunatic Member
    13,419
    SE Michigan, Downriver....
    Congrats. They are decent stuff.
    I picked up an MCS 3835 fairly cheap.
    Enjoy.
    Vintage Unit likes this.
  3. Vintage Unit
    12
    What might be the cause of the memory loss? Please say its something that doesn't require intelligence or soldering. Not that I care that much. It takes 5 seconds to retune.
  4. Hifirob2
    Hifirob2 NEC and Klipsch rock!
    3,679
    So Cal
    There is a Ni-Cad battery inside (should be mounted on the circuit board near the power supply) that probably is not holding a charge after all these years. You can replace it with a new one - although I'm not sure the same size & value is readily available. It was an odd shape, if I recall (the 3260 uses a similar type).
  5. Vintage Unit
    12
    It seems to have held overnight. Maybe having the unit on for a few hours last night charged that baby up. But I need to go in there at some point to look at the tuning bar so I'll see what kind of battery it is. Thanks!
  6. Vintage Unit
    12
    Here's the innards in case anyone's interested. I saw NEC in there somewhere, as I expected to.
