Spectrum17
New Member
I recently purchased a pair of older Sansui receivers, an 881 and a Seven. The 881 responded well to a light cleaning and is currently in use. The Seven on the other hand needs some attention.
I've cleaned and lubed all the switches (which by the way have all their labels intact) an pots. It appears the pre-amp section is fine, as I can send the signals to an external amp it it sounds just fine. When I use the on board amp section I only get sound from the right side and only very faint. I'd like to know where I should start my investigation. I am only armed with a schematic and DVM. Is this something that I should attempt or take it in and have it serviced?
Thanks
Thanks
