rlisin
Quad 4 life
Got my hands on an InKel set of MD2200, PD2100 and EQ 200 (power amp, pre and EQ):
Power and pre were also sold as Sherwood S-6040CP/S-6020CP and as LXI AM 4222/AM4022. I put Sherwood model in the title because I know some ARers have this amp.
The power amp needed adjustments, which I made. At first I missed that 8 ohm load should be connected while adjusting and I couldn't get the right values, but after rechecking the SM I connected an 8 ohm speaker and adjustments went fine. Well, sort of.
I could get the bias to the value range specified in the SM with VR102, but it's not the same on transistor pairs in either channel (off by 2 mV, meaning when I set it to 17 mV for one pair, the other pair in this channel gets 19 mV). Both values are within the range recommended in the SM, so I don't think it's a problem, but if it is, do tell me.
DC offset was more tricky. I could not get it down to near 0 mV using the VR101. According to the SM, values up to 70 mV are fine, but 70 mV seemed scary high to me and I wanted it lower.
But there is a 3rd trimmer on the power board. The SM simply does not mention it and I don't see it on the schematic at all. The reason is, SM is written for the power board part number K40430, and my amp has power board K40430A.
When I moved this trimmer (by mistake), I noticed that it affects DC offset big time, so I set it in the position at which DC offset is 0 mV.
But I hate to not know what exactly I'm doing, so I would like to set it correctly.
So, do you have any idea what the 3rd trimmer does?
It is marked red:
X marks the spot where it should be on the schematic:
I have confirmed that the 3rd trimmer is not unique to InKel-branded amp, some Sherwood S-6040CP and LXI AM 4222 also use power board version K40430A and also have this trimmer. It is not on power board K40430.
It is marked red:
