N44E/improved or N55E/improved
Discussion in 'Turntables' started by MrGrady, Dec 8, 2018.
  1. MrGrady
    MrGrady Active Member
    104
    I have a Marantz 6370Q turntable with a Shure M44E cartridge.
    I wanted to try a Jico stylus. But I don't know which would be the better choice.
    I'm currently tracking at 1.5 grams.
    I listen to a lot of different types of music i.e. rock, jazz, blues, classical .......
    So which one would you pick, and why?
    N44E/improved or N55E/improved?
    Thanks
  2. Evonimos
    Evonimos Active Member
    182
    I have no experience with the N55E stylus.
    Neither, JICO or other aftermarket styli.
    However, from the original options for that series, I'd rank the N44-7 at the top of my list.
    If you are happy with your original N44E, you would be even happier with the N44-7.
    The N44C heavy tracking option, must come second and is also very pleasing.
    The N44E and the N44G, are very similar both in tonality and in tracking, to the classic N44-7 with only minor sonic differences.
    Great options, as well.
  3. MrGrady
    104
    I'm not really sold on a conical tip.
    That said, I don't think I ever listened to a conical tip stylus.
    Here's my reasoning: with an elliptical tip there would be more surface area on the vinyl. Which should produce more information. Which should be more musical.
    I'm not really educated on this.....and I could be totally wrong. :)
  4. Evonimos
    182
    If you find an original N44-7 at a fair price, I'd suggest you try it and be the judge.
    From my own experience and testing, the N44-7 is a bit superior sonically, to the very good N44E.
  5. MrGrady
    104
    Well I went ahead and did it.
    I order both the N44-7/improved and the N44E/improved from Jico.
    Between breaking in new tubes on my amp, phono stage, and new stylus.......... This should a pretty fun month.
  6. Calypte
    Calypte Temecula, California
    138
    Anza, California
    Have you ever looked at the "So you want to know stylus shapes?" thread? The spherical tip has the smallest area of contact with the groove wall of all stylus configurations.
  7. MrGrady
    104
    Thanks
    I went ahead and registered with them, so I could access all the information.
    Hopefully this will educate me.
    Thanks again
  8. Greenie
    Greenie AK Subscriber Subscriber
    39
    Wimborne UK
    I'd be interested in your thoughts when you get them.
    I purchased the Jico N55E (improved) stylus a year ago and it's still on the old Garrard DD75. Sounds just a bit better than the original Shure it replaced. Not so much more treble, just better defined.
    I finally got my sibilance test record (Al Stewart's Zero She Flies) to play acceptably, never quite did with the old stylus.
    I play at 1.6g , which may reflect more on the arm than anything.
  9. MrGrady
    104
    They should be in this week.
    I'll give a shout out, once I've done a little break in.
