drbiggles
I like to pull weeds.
Hey everyone!
I don't post here very often, mostly in the Speakers forum. A friend who's not able to be here, asked me to stop by and see if you had any answers for him. Please help!
The subwoofers in question may be Cambridge ASW-1's. I do know they're powered and a stereo pair.
He knows about installing the subwoofers to the Tape Outs. But he wants to have the volume knob on the preamp to also adjust the volume of the subwoofer. More specifically, "what's up with the two separate pairs of outputs on that particular preamp." If those 2 sets of outputs work for 2 amplifiers, why not the 2 powered subwoofers?
"The NAD 1240 has two pairs of outputs, 1 and 2. Each set has a R and L channel. Output one goes to the power amp. I was trying to use output two R and L to go into the R and L of a stereo pair of subwoofers. Every time I plug into output 2, it mutes one of the main speakers. When I unplug from output 2, the speaker is back on, normal stereo operation. Is this normal? I can only guess that the preamp, somehow, when you use both outputs simultaneously, thinks you are adding a second power amp and bridges both to MONO automatically so that output 1 becomes R and output 2 becomes L. This would explain why I lose one of the main speakers via the power amp. It's sending everything to the subwoofer. Is this correct or is the preamp not working properly?"
Biggles
Biggles
