teal'c
Nuclear Cardiac Parent
Picked up this off the Bay for a Franklin but the seller packed it using air pillows.
The forty pound receiver probably popped them in the first twenty four hours.
Fortunately the front was undamaged and everything seems to be working, but one corner was indented/bulged on the side/top.
That was pretty easy to fix although it's obviously been messed up, it's flat once again.
The bigger problem is in the back, The area in between the speaker connections is dented in. How it was managed without puncturing the box... It wasn't in the sale pics, but you be the judge.
This has been giving me . I pulled out the board above it.
That whole connection assembly is direct connected to a circuit board and is too big to pull out. See those curves in the top middle of the pic? Those are solid bars of metal connecting the board to the speaker outs.
The longer bar on the right is +, shorter on the left -, the dent is in line with that center support in between the two. Too tight to get a screw down there. I'll be trying it with a nut after dinner, but I'll be surprised if it works.
