Timothy Flath
Just stumbled on a nice Nakamichi RX-505 last night from a local fellow here in town and bought it on a whim with an accompanying Nakamichi TA-2A Stasis Receiver. Unit works quite good and sounds very good on playback (although I need a better tape to make that complete assessment - pre-recorded tapes don't count). Went to record a mix tape on it like the old days and when on "Source" the levels incoming read fine. Since it is a 3 Head deck I then poked in the "Monitor" switch (Source/Monitor) using a brand new freshly opened Maxell XLII for a trial (set of course on Type II using Dolby B and then C for separate runs) - the rec levels being read off the tape directly are very very low with right side reading a bit higher than left. Sound is getting imprinted on the tape but extremely weak, lop-sided and poor quality levels. Anyone know if this is a common issue with these? Could it just be a dirty source/monitor switch not letting the sound through (that is my next thing to try is to see if the switch is accessible and if I can hit it with D5 knowing that this beast is getting on in age)? Just going to poke around on HiFi Engine as well to see if I can find a service manual to give me some more insights as to problem areas and where to start troubleshooting. Of course will give the heads a good clean as well.
