Soun!
New Member
Hello everybody!
The above integrated amps just popped up locally. I've heard they have a sweet sound, but wanted to know if they are truly musical pieces… Not going on wattage here, just which one is the better sounding (especially in the BASS department: I love organ music) of the three.
In my understanding, NEC and Denon are straight class AB affairs, whereas Luxman is a class A/AB (first few Watts delivered in class A) design.
Please chime in, and help a newbie!
FYI:
Denon PMA-900V
Power output: 120 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.003%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 77dB (MC), 95dB (MM), 107dB(line)
Output: 150mV (line)
Dimensions: 465 x 157 x 397mm
Weight: 11.6kg
NEC A-910
Power output: 100 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 40kHz
Total harmonic distortion: 0.006%
Input sensitivity: 0.25mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 70dB (MC), 90dB (MM), 96dB(line)
Output: 140mV (line)
Speaker load impedance: 4Ω to 16Ω
Dimensions: 430 x 151 x 383mm
Weight: 16.5kg
Luxman L-410
Power output: 75 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 100kHz
Total harmonic distortion: 0.015%
Input sensitivity: 0.1mV (MC), 2.5mV (MM), 200mV (line)
Signal to noise ratio: 67dB (MC), 87dB (MM), 110dB(line)
Output: 200mV (line)
Dimensions: 453 x 425 x 135mm
Weight: 13 kg
FYI:
Denon PMA-900V
Weight: 11.6kg
NEC A-910
Weight: 16.5kg
Luxman L-410
Weight: 13 kg
