Markoneswift
Quartz locked n ready to rock
Hello all,
I'm working on my Sharp VZ-3000 system and currently, I'm trying to work out why I am seeing unexpected voltages at the STK463 IC pins..
I see 9.2 volts at the input pins 1 and 16 - which according to the schematic should be at 0 volts with no signal going in. I also see quite a few pins at +31 an -31 volts which seems wrong, along with 9.2 volts at pin 9.
I would like to know whether R417 being out of spec would cause these strange voltages to be present around the IC. When I measure R417 which should be a 100 ohm fusible resistor, I see resistance rapidly rise to open, then it backs down, then goes up again.
I've checked all other resistors in the circuit and they are good, but I have not replaced any caps yet - could some of the filter caps being bad mean the inputs are seeing DC when it should be filtered out ?
If you guys could please have a look at the schematic for the power amp below, I would be very appreciative of any help with this. Cheers
