Gingahippy
Hello again,
So I have the task of installing a sound system in a salt/massage spa. Current bluetooth units are not working out and we don't want unnecessary EMFs since it's a health environment (not open for discussion however woowoo that may sound) so we're looking at hard worried speakers mounted on the ceiling panels in each room and reception with cables running across the drop ceiling cavity.
I'm thinking a nice amp in the office with cables running up into the drop ceiling cavity to 2 speakers in each therapy room, 5 rooms in total. Music will be the slow, soporific variety played at low volume, same tracks played across the whole spa. We will need volume control in each room, I'm thinking a simple knob on a box that hangs down against the wall, we are not cutting onto any walls to install anything.
My main questions for the group are:
1. Will I need 2 speakers in stereo or will one speaker in mono per room be good enough for that quiet spa music? Obviously we'd all like to hear 2 in stereo but there may be really good mono options that I don't know about and clients sitting under one speaker may get an unbalanced sound if it's stereo.
2. Will I be able to run all the speakers from a simple 2 channel amp with enough power or should I be looking for a specific amp for multiple outlets like a surround system AVR?
3. Will the speakers need to be identical or could I use different speakers as long as the specs are close enough? Obviously the ohms will need to all match. How much can the wattage vary and how much does that mess with things?
4. Will I need to have some kind of cabinet behind each speaker cone or will the open back be okay under the circumstances?
5. Will it be better to run parallel or series? I'm assuming running in series will create too high an Ohm load for the amp but I'm not great with this aspect of electronics yet.
I am trying to keep the price as low as possible since it's a new business and they have very little money, I'm thinking about buying up average speakers from Craigslist and maybe just removing the cones to mount in the ceiling panels, that's how basic and ghetto this project will be to begin. I'm just trying to find the parameters that I NEED to stay within for this to work. Several hundred bucks for a dedicated system is not possible right now. I work at the spa and the owner is a friend so I have total control over this project and whatever I do they will be grateful, no need to make this a pro job, yet.
Open for thoughts and discussion my fine audiophile friends. Thanks in advance.
