I recently bought a m2 and corresponding c2a preamp. Problem with the m2 is that it does not work. Buttons don't light up. So I checked some of the test points inside. On the outermost boards I get 80 volts, which is correct. I don't remember which stage it is. But the inner boards get no power. Also, there are test points at the front of the amp that should be 12 volts and 100 volts. I get 30 volts and 175 bolts respectively. I can circle these points on a schematic if needed. Just seeing if anyone has run into this issue.
