Need help identifing speakers
Discussion in 'Speakers' started by Pat Kettler, Sep 11, 2017.
  1. Pat Kettler
    Pat Kettler New Member
    5
    These are Electro voice speaker cabinets put together by my Dad, early '50s. But I think they may be JBL speakers. Does anyone know for sure? There is a knob in the presence position labeled JBL.
  2. lifer70
    lifer70 What? Subscriber
    641
    Boise, Idaho
    That bullet tweeter looks JBL.
  3. portnoy
    portnoy AK Member
    1,187
    Eastern Shore, MD
    Do you have a pic of the connectors in the back? If it looks like a complicated connection that would involve a matching mid level speaker on top then it's the Heath-Kit (Radio Shack) ... something or another.
  4. Pat Kettler
    5
    The regular old speaker wire lying on the floor goes inside and up the front. The connector on the outside has nothing connected to it.
  5. portnoy
    portnoy AK Member
    1,187
    Eastern Shore, MD
    Yeah I've seen electro-voice's with those mid / high attenuator knobs on the side like that.
  6. toxcrusadr
    29,881
    Central Missouri
    EV Aristocrat cabinet.
    JBL 075 "bullet" tweeter.
    Maybe a JBL D123 woofer.
    Nice setup!
    You'll want to check around inside and make sure the wiring and crossovers are OK. You could connect the rear panel input jacks while you're in there. The Aristocrat has tiny screws on the front where the grille cloth meets the square frame. Gotta look for them. Then the front will slide out, DOWNward. So it will have to be on its side or back or upside down. [Edit: I see you got the fronts off already, duh]
    Take your time, these are very cool especially since they're from dad.
  7. Pat Kettler
    5
    Thank you so much for sharing your knowledge!!!! I thought about taking the panel off behind the front cabinet panel, but didn't want to take the chance that I would split the wood or strip the screws. Did I reduce their value when I changed the front fabric/metal cross hatch when I was younger... thought it was not very attractive?
  8. toxcrusadr
    29,881
    Central Missouri
    Well maybe but I have seen different versions of the Aristocrat as I recall. They are not super valuable in the marketplace, probably your drivers make up the majority of the value if they are working and genuine JBL. As long as you take reasonable care (avoid poking those woofer cones with a screwdriver, it happens quite often!), if there is brittle wood or bad screws those can be fixed or replaced. These are like an old car, it's OK to change tires, and it's not a '32 Duesenberg. :p The main thing is that you have good quality drivers there and you aren't even thinking about changing them out (nothing to be gained there), so everything else is details.
    You can remove the woofer to get inside the cabinet unless it is mounted from the back. In which case, better to remove the whole panel if you can.
    If there are ancient crossovers in there they might be due for some new capacitors anyhow. Wouldn't hurt to take a look and post some pics. And the rear of the drivers would clarify exactly which drivers they are - especially the woofer.
  9. toddalin
    toddalin Super Member
    1,997
    Most probably a JBL D123 as evidenced by the voice coil leads, the dome (which appears to have been smashed in), the ribbed cone, and the edge.
  10. Nat
    Nat AK Subscriber Subscriber
    12,315
    I believe it is a EV Marquis cabinet. Fully stuffed, a good sounding speaker.
    The JBL drivers are desirable, but the L75 is capable of being very bright if not padded down. And subtlety is not its strong suite.
