Need help picking a DIY kit for tube headphone amp
Discussion in 'Tube Audio' started by ikorman, Mar 19, 2012.
  1. ikorman
    ikorman Active Member
    276
    Folks, I would like to attempt a build of a tube headphone amp. I listen to headphones quite a bit so it makes no sense to run the whole big amp to do that. Also, I just discovered tube sound with a Heathkit AA-121, and I am not going back to solid state...
    So, where do I find a kit for a nicer tube headphone amp? I head stuff for $50 has drawbacks, so I might as well spend a bit more and get something without compromising. Any help will be appreciated.
  2. ikorman
    276
    P.S. Looking at something called Project Sunrise II, how is it?
  3. gguillot
    gguillot AK Subscriber Subscriber
    1,665
    Indianapolis, IN
    Check out Pete Millett's "Jonokuchi" headphone amp. I have heard good things about that one. Pete sells the circuit board on ebay - just do a search on "Jonokuchi." It requires more than a $50 investment, but looks like a high quality design.
  4. apurcell22
    apurcell22 Well-Known Member
    521
    Vacaville, CA
    +1 on the Jonokuchi. I built one and it sounds very good. It also doubles as a low power SET speaker amp. It's also an easy build.
    Al
  5. BmWr75
    BmWr75 Addicted Member
    5,269
    Northeast MS
    Bottlehead Crack kit if your have high impedance cans.
  6. ikorman
    276
    Just for follow-up...
    I ordered all the stuff for Jonokuchi and most of it already get delivered, only thing missing are transformers. Dang! Five-six weeks wait sucks. So I got a Bellari HA540 to keep me company till the Jonokuchi gets done. Bellari sounds really great with my ATH-M35 cans. Makes me wonder why I spent close to $300 for Jonokuchi parts, but I haven't done the comparison yet...
  7. kansei
    kansei Super Member
    3,018
    New Jersey
    I built the Starving Student, the "Super Simple 6dj8" and a Bijou.
    My favorite was the "Super Simple", although it needed a really good tube in there to really shine (JAN 6922 worked really well in my case). Parts cost was around $70 including the enclosure. You could also look on eBay for 6dj8 headphone amps and put good parts in the signal path, they cost around $80 as well.
  8. ikorman
    276
    I just finished the Jonokuchi today, what a feat for me, a lame amateur! I decided to perform the described mod to get rid of the hum. I screwed up at first, leaving the left channel with a resistor still in place so the right channel was 6db louder till I figured out what's wrong.
    Either way, the long-awaited comparison with Bellari and Jonokuchi is trailing. Even with the mod, Jonokuchi has the hum. Bellari is DEAD quiet. Musically, they are about the same, at least to my ear.
    I am keeping Jonokuchi, however. If just to play with small speakers. I will run the internal speaker wiring tomorrow and try something small with it. I doubt it can run my Klipsch Heresy pair, but let's see...
  9. TerryO
    TerryO Super Member
    4,157
    Seattle, Washington
    As I have been using Sennheiser Headphones for over 35 years, I would definately go with the Bottlehead "Crack" HP amp.
    Best Regards,
    TerryO
  10. ikorman
    276
    I heard great things about this, but 2 headphone amps is enough for me. Running out of room over here!
  11. cary
    cary Active Member
    357
    San Francisco
    Bottlehead Crack or the SEX amp. I built the SEX amp and really love it, it's dead quiet, the Crack kit is the most popular kit from them. Bottlehead kit instructions are very very easy to follow almost idiot proof. Check out their web site lots of happy customers.
  12. gogofast
    gogofast AK Subscriber Subscriber
    7,865
    Seattle
    i got an email from bottlehead saying they're offering free speedball upgrade for the crack amp now.
  13. gguillot
    1,665
    Indianapolis, IN
    ikorman,
    Did you see this thread with the reply from Pete Millet? (Look at post #68)
    http://www.diyaudio.com/forums/tubes-valves/182269-jonokuchi-new-desktop-amp-little-red-board-7.html
    Hopefully you can get your hum issue sorted out. You at least have to be proud of building your first amp!
