z-adamson
Addicted Member
Device: Sansui Z7000
Problem: Following the SM instructions, with 8ohm dummy loads connected, measuring and adjusting for +25vdc and -25VDC at pins 9 and 10 of the STK3106 module, all is well with the -25vdc adjustment. However, the +25VDC adjustment is not going so well in that I get 19.8VDC and as I adjust the variable resistor in pursuit of the 25VDC, the voltage reading does not change. No matter where I have the variable resistor set, the test point at the STK3106 is fixed at 19.8VDC. And no I am not probing the wrong test point. It is as though the VR has turned into a fixed resistor. So I measured ohms at the VR solder pads and it does change as I turn the VR. I also tried two different new STK3106 modules.
Now, it is also worth noting that the SM states that once these adjustments are made, you are to measure DC voltage at the speaker binding posts and you should see 0 MVDC plus or minus 200 MVDC. I get 30mvdc on one and 50mvdc on the other. This suggests that I am good to go because it is within tolerance. But I am still irritated that the circuit does not respond to the VR and that I have 19.8VDC where I should have 25VDC.
All the electrolytic caps, variable resistors, relays and the STK are new.
What to do....?
What to do....?
