240sx4u
Lunatic Member
Heres the scenario. This may be rehash for some people, but its a background (I had posted some info in another thread). I aquired this unit with a low output channel. One of the fuses for the power supply to the driver board was blown. Just for giggles I put a new one and It did not blow on me.
I then went to set the bias and offset of this unit. The service manual is wrong (as pointed out by a member) and indicated that I had to turn screws clockwise to lower the bias fully (blatantly wrong, I cant belive I actually did it). Basically at this point in the game the unit would work with normal channel levels but make a DC pop out of one speaker after the amp warmed up.
I was not able to get the dc offset and bias set properly on one channel. I also treated the sockets for the boards with deoxit, which actually did change the voltage I was able to obtain (but it was still way too low). I also checked all the voltage regulation DC numbers from the schematic and they metered out just fine.
Fast forward to now.
It had never occurred to me to check the output of the headphones when I was tinkering. I found out later that the headphones had only one side working. Who knows if thats my work or not. I found a few cooked resistors on the suspect driver board. I am trying to figure out what burnt the resistors.
I have checked every resistor on the driver board, tests fine, same deal with transistors (bought a tester). I also metered across the caps. Everything seems fine there as well. A tech at some point had replaced two transistors and a DC offset pot.
I have desoldered the bad resistors that I found on the board and ordered new ones. That is where I stand right now. Is there any other testing that I can do with this thing before I get my new parts to install (i ordered 2 of each in case they cook again). I also plan on replacing the pots after I get this situation figured out. My shaky hands have trouble tweaking single turn pots.
Oh, and I did swap the driver boards back and fourth and the bad channel did not change. I know that means the crux of the problem may not be on the driver board (but I still need to figure what smoked the resistors).
Thanks so much guys - Evan
