Need help with Yamaha R-900 any owners out there to take a pic for me?
Discussion in 'Solid State' started by saabracer23, Feb 5, 2018.
  1. saabracer23
    saabracer23 AK Subscriber Subscriber
    807
    Salem, Oregon
    I have an R-900 in front of me that has a burnt resistor and two more resistors in the same circuit that look pretty crispy as well. There is no way to read what the value was on the burnt one. It came from the empty space below.
    You can see the two resistors right above those transistors that look pretty toasty as well. I can’t get a value on those either, I can only get the colors on the two middle bands the two channels are not alike.
    The service manual and schematic are extremely difficult to impossible to read and what can be read seems to be wrong. The resistor that burned to a crisp, the service manual board layout had a diode in that position. The value for those other two resistors that look crisp according to the schematic are 680 ohm which they clearly are not since they have orange/white or orange/yellow stripes as the center stripes. I don’t even see 680 ohm resistors in that entire circuit.
    Anyways I was hoping maybe someone with an r-900 would be willing to pop the top and send some clear closeup photos of the two amplifier circuit sides.
    Dan
  2. Hufsredo
    Hufsredo Member
    59
    Hanford CAli
    I bought an R900 for parts, Ill take a look.
  3. Hufsredo
    Hufsredo Member
    59
    Hanford CAli
    That must be a common issue, those are fried on the left channel on the board iv'e got. On the crispy one I can see the first band is red with a 5% gold
    on the end. The green cased ones are either X white red or orange gold, you might be able to find something on the schematic that fits. I can post pics but they won't help much, the crispy one even burned the board.
    goodolpg likes this.
  4. Aspen
    Aspen Active Member
    317
    London, Ontario
    I will look tomorrow
  5. Aspen
    Aspen Active Member
    317
    London, Ontario
    Red red brown gold, decided to look through the vent in the cover. I have the service manual somewhere too. There's another crispy one at the top of your pic. Stk 1070 may be pooched. I posted a source for some nos ones a while back.
  6. avionic
    40,078
    Fort Dodge, Iowa
    Look for the identical twins on the other channel.
  7. avionic
    40,078
    Fort Dodge, Iowa
    I'd be checking transistors and diodes in the immediate circuit of those resistors.
  8. avionic
    40,078
    Fort Dodge, Iowa
    That big black STK1070 II is suspect as well.
  9. avionic
    40,078
    Fort Dodge, Iowa
    There should be two like them close to the other STK. Hard to say what color they are / were. They have been cooked. How many ohms do they measure ? Probably "open" like a fuse.( fusible resistor )
  10. telemike
    telemike AK Subscriber Subscriber
    2,180
    Greensboro, NC
    I had an R900 in college back in the 80s. I smoked the power chip on mine. Ran hot.
  11. Aspen
    Aspen Active Member
    317
    London, Ontario
  12. Aspen
    Aspen Active Member
    317
    London, Ontario
  13. Aspen
    Aspen Active Member
    317
    London, Ontario
    Having trouble getting a good shot uploaded.
  14. avionic
    40,078
    Fort Dodge, Iowa
    Whats the color code on those two green resistors close to the chip amp.
  15. avionic
    40,078
    Fort Dodge, Iowa
    Gold being the fourth band.
  16. telemike
    2,180
    Greensboro, NC
  17. Aspen
    Aspen Active Member
    317
    London, Ontario
    Looks to be gold, brown, red, gold
  18. Aspen
    Aspen Active Member
    317
    London, Ontario
  19. saabracer23
    807
    Salem, Oregon
    So yours are like the amp I have, on the one channel the two middle bands are orange and white!
    So the two channels aren’t identical, wish it was that easy.
    In the other channel they are 820 ohm, which it looks like Aspen’s unit has in his channel. In his photo it appears I see a grey, red, brown, gold. Maybe it came from the factory different or it was worked on in its past. The ones in there are measuring in the mega ohms.
    I assumed the STK device was bad and suspected that the voltage amplifier may need to be replaced as well. Looks like I’ll just go with the 820 ohm resistors in both channels. The service manual calls for 680, to bad it’s nearly impossible to read. Did the manual come from Yamaha like that? There has to be a better document out there in the world.
    Thank you, much appreciated!
    Dan
  20. avionic
    40,078
    Fort Dodge, Iowa
    On the schematic they are. They are electronically identicle. Id´use the 820 Ω to replace those two french fried resistors.Layout on the board is different.
