Need some help with my Infinity Monitor IIA's
Discussion in 'Infinity Loudspeakers' started by Galaxie65, Nov 26, 2018.
  1. Galaxie65
    Galaxie65 Always looking for new gear to try Subscriber
    2,991
    Denver, Colorado
    So I snagged a pair of Infinity Monitor IIA's and I'm going to start the process of bringing them back to life. I didn't realize that there was a forum just for Infinity...... So I started a thread in the speaker forum..
    Here is a link for reference, however I will ask a few questions here.
    What woofers can I use that are replacements or as close to original for these monitors? I have some oddball woofers that are inside and I need to replace them. So if there is anything I can source I'll start there.
    The mids need a little help as the wire is broke on both, naturally right?
    Any help would be appreciated folks!
    http://audiokarma.org/forums/index....nitor-iia’s-tonight-need-some-woofers.846863/
  2. CDELON
    CDELON Active Member
    171
    PA
    Congrats on the find.
    This site can be helpful. Infinityclassics>de>technik>manuals
    12inch woofer NLA
    Substitute: 902-1187
    1 1/2 inch midrange NLA
    Substitute:902-0206
    Tweeter 902-0129
    Super Tweeter 902-0060
    Hope this helps. You could do a Google search or check Ebay for the woofers. If they can be found, your in the right place. Someone should be able to direct you to a set on AK.
  3. Galaxie65
    2,991
    Denver, Colorado
    Thanks! I did get a .pdf of that and I'm happy it was available. Another member gave that to me so it has helped out. I'm still looking to source the woofers but didn't have luck finding any on the bay.
  4. tubed
    tubed Lunatic Member
    16,114
    Aztlan
    Hens teeth rarity are the 12 inch originals, however the 12" poly replacement show sometimes on the bay.
  5. goodolpg
    goodolpg Just an old fart trying to help.
    Ok, if, IF, IF the 902-1187 is an appropriate replacement, then 490602 (clear cones) and 490702 (gray cones) may also work.
    Only concern is I think the Monitors had the doped cone woofer as OEM, and the 1187 and 602/702 all have poly cones.
    But if indeed they are valid substitutions that would allow you to cast a wider net in your search.
    Good luck!
  6. swechsler
    swechsler Frog Whisperer
    5,428
    7th row center
    Don't rely on remembering to do a search on eBay. Set up an automated search for the model numbers of the woofers, and also look for the speaker name (and others with compatible drivers) with the word woofer.
    CDELON likes this.
  7. CDELON
    171
    PA
    Swechsler is correct. Broaden your search terms. I have found woofers in the past under Infinity speaker parts. They only needed refoamed. They didn't come up in the others searches that I did. I don't believe that item designation is even a option when selling. ?? But there they were.
