bobbyrae
The Audiophile Farmer
Bought this intgrated amp and it sounds great, but the power meter lamps are burned out.
So I got the service manual. Guess what? The schematic says NOTHING about the voltage or current draw of those lamps!! GRRR
So I looked at the supply - it's 85 volts for 4 lamps in series, meaning they are drawing about 22 volts each. Trouble is, they only seem to make these in 14v and 28v. My initial guess was 24v.
The next problem was figuring out the current. Since they all appeared burned out, I was clueless. But then, close examination showed that ONE was still good! So I hooked it up to a power supply that would put out 20v. The current at that point was 100mA.
So what should I conclude about the ratings? Initially I thought 24v, 120mA. But if it was a 28v, then the current would be 140mA.
This is looking kinda hopeless because I just can't find anything even close. See attached photo. I think the shape and size classifies them as T 1-1/4.
And dwojo? He doesn't seem have anything like that.
