Need Temporary Class-D Amp. Suggestions?
Discussion in 'New Gear - Values' started by dewdude, Nov 3, 2018.
  1. dewdude
    dewdude High on resolution. Subscriber
    3,152
    Manassas, VA
    So...while I've kept up with what a Class-D/Class-T amp is and the theory...that's as far as it goes. I know I heard the name Tripath pushed around a lot; welcome to the extent of my knowledge.
    My trusty Motorola tube amps have been acting up over the last two years and they're at a point where they're blowing tubes left and right...so I've had to take them out of comission while I decide what I'm going to do. This leaves me with nothing in my office/radio-shack/avoiding-people-area. Here's my audio chain:
    SMSL M8 DAC -> Little Bear P5 -> Sansui SE-8 -> Yaqin MS-12B
    Right now I'm using a Denon AVR-591...my vintage Denon has been in need of a relay you can't get.
    I highly suspect with the amount of DSP this Denon has it's probably digitizing my analog input (even in bypass mode)...which is not what I want. I have some faith that class Ds probably aren't doing any processing other than whats required for processing...which I assume is some kind of super-high-rate PWM type conversion. Close enough for me I guess. I do a lot of listening to high-resolution PCM and DSD on my setup.
    If anyone can make some suggestions of something around $100 I'd appreciate it. I'm probably going to just order it from Prime so it gets here ASAP.
    *edit: I just did some thinking and with the life plans I've got..I'll probably be using this thing for a while since I should probably put off dropping loads of money in to my tube amps when I might not be able to use them in about a year and a half*
    E.Man likes this.
  2. PAGS
    PAGS AK Subscriber Subscriber
    2,220
    North of Philly
  3. dewdude
    3,152
    Manassas, VA
    I think I saw someone raving about this one. I may have to sleep on this for a few nights. I can limp along on this Denon. Plus Sunday delivery from Amazon has never worked out well for me.
  4. 59volvo
    59volvo Super Member
    1,063
  5. KlipschFan61
    KlipschFan61 Smooth Jazzer
    987
    Manchester, NH
