How do you understand feedback masks detail from your sources? Can you explain or even describe this mechanism?
Please do not take this as a rant but just as a sanity check:
I fail to understand how complex sentences that start with 'feedback is' and possibly continue with 'good/bad', AND then have one or more of 'when/because/in case of's and similar, with each of those having multiple 'if/but/or/not clauses' to them, end up conveniently shortened to 'feedback is good' or 'feedback is bad' in audiophile circles, while the mid sized book that follows is interestingly 'forgotten'. Why is that? Is it because it's so much easyer to memorize the currently fashionable mantra, whereas it takes REAL effort figuring out how and why it all works? Lets face it, this is not simple stuff when one really digs into it. And as Einstein said, things should be as simple as possible - but he also added, BUT NO SIMPLER.
In a perfect world, where amplifying elements of circuits are perfectly linear and, come to it, otherwise perfect, feedback would just be a needlessly complicated way of doing something that is already inherent in the circuit. But we do not live in a perfect world. Feedback is a tool - and like any tool, it's not inherently good or bad. It's all about what you do with it. Kind of like a hammer. It's good if you hit a nail on the head, it's bad if you hit yourself on the head. To use it, you need to first learn which end is the business end, and which is the holding end. Granted, there are several ways of learning - you certainly do learn if you survive the hitting yourself in the head part
I do admire that you wish to experiment for yourself. There is far too much dogma in audio, and trying things out is one way to avoid this - though you still need to know how to interpret the results. One thing which is typically done in experiments, is insuring within reason that only one variable is changed. In your experiment, this is not the case. As a reality check: you could just as well enhance the details in your sorces using a carefully designed tone control.
