Never had a DAC before....please help with two questions.
Discussion in 'DACs' started by Rob41, Feb 3, 2018.
  1. Rob41
    Rob41 Don't stop believin'
    2,626
    Northern Michigan
    Thanks for reading my post. Like the title says, I've never had a DAC before so I have a couple questions.
    I no longer use vinyl, tape or any other analog source so all my sources are now digital. I've looked all around the web and at pictures but don't see what I'm looking for, if it's even possible.
    1. Can I get a DAC with RCA inputs and outputs?
    2. If so, of this type, are there a couple under $100 that perform at least mid-fi level? No offense intended.
    Thanks!
    -Rob
  2. spark1
    spark1 Super Member
    1,761
    The Great Midwest
    Yes on rca outputs, no on rca inputs...because input is digital (coax, optical, usb, etc).
  3. vonclod
    vonclod Super Member
    1,465
    Vancouverish
  4. gvl
    gvl Super Member
    1,082
    I sense confusion. What do you want to do with RCA inputs???
  5. Rob41
    2,626
    Northern Michigan
    I wanted to connect the DAC between my preamp outputs (RCA) and my amplifier inputs (RCA). I'm getting the impression this is not how it's done. Would this not work?
  6. gvl
    gvl Super Member
    1,082
    Nope, you need a digital into the Dac, analog out. Digital is usually coax, optical or USB from computers .
    stish likes this.
  7. abpeep
    abpeep OU Sucks!! Subscriber
    3,301
    Buda, TX
    An Emotiva DC-1 has a set of analog inputs but this is just a preamp circuit which bypasses the DAC. The Maverick also has this analog preamp circuitry. The DC-1 has five types of digital inputs for doing digital processing. And it's $499...
    mjw21a likes this.
  8. soundmig
    soundmig AK Subscriber Subscriber
    1,786
    Western Colorado
    No, you need to run from the digital out (coax -rca, optical or USB) of your digital source (CD player, computer). The DAC (Digital to Analog Converter) then sends the analog signal (L&R RCA's) to your preamp. From there everything hooks up as normal; pre-amp to amp to speakers.
    ldatlof and Rob41 like this.
  9. spark1
    spark1 Super Member
    1,761
    The Great Midwest
    The Maverick rca inputs are not for digital conversion.
    OP, I assume you have multiple sources. Some DACs allow input from multiple devices, with a source selection function. But not under $100.
    mjw21a and Rob41 like this.
  10. Rob41
    2,626
    Northern Michigan
  11. vonclod
    1,465
    Vancouverish
    Your preamp is already putting out an analog signal, a DAC is for converting a digital signal into analog..ie from your computers usb, or a cd players, dvd player's coax..etc
  12. vonclod
    1,465
    Vancouverish
    Yes I'm aware of that..hence the question about what the OP was trying to do.
    "When you say RCA input, are you meaning coax digital or l and r analog?"
  13. spark1
    spark1 Super Member
    1,761
    The Great Midwest
    So if your digital sources all have their own DACs (CD players, computers, media players, etc) then you don't need an external DAC...other than to potentially improve on sound quality (some external DACs are better than some internal DACs).
    mjw21a and I LIKE MUSIC like this.
  14. Rob41
    2,626
    Northern Michigan
    In my other thread you can see my preamp is also my CD player, DSP etc, etc. and then some, lol. Even if I add a flac player via the aux or USB port, the signal will still go through the digital realm of the head unit.
  15. spark1
    spark1 Super Member
    1,761
    The Great Midwest
    I was assuming he wanted a DAC for digital to analog conversion.
  16. Rob41
    2,626
    Northern Michigan
    All of my sources are part of the Pioneer head unit which is of course also the preamp and DSP. To the best of my knowledge, it does not have an internal DAC. I am looking for a Digital to Analog convertor for the whole thing. It doesn't look like that will be possible though?
    Sorry for the confusion. I should have said it was for a car stereo (in home though) head unit.
  17. spark1
    spark1 Super Member
    1,761
    The Great Midwest
    I think it must have an onboard DAC...how else would it process FLAC files and CDs, for example?
    I'm sure I'm missing something, but it sounds like your system/head unit is already working fine with digital inputs...that is, it is taking digital in and sending analog out to your amp.
  18. Rob41
    2,626
    Northern Michigan
    Good point. I did some cursory looking but I'll have to dig deeper.
  19. Rob41
    2,626
    Northern Michigan
    It of course does work with digital inputs and process FLAC files. My lack of understanding sure has caused some confusion. Sorry for that guys!
    And thanks for the help. :)
  20. vonclod
    1,465
    Vancouverish
    Yes, for the usb port, your head unit will be using its built in DAC, as the head unit does not have a digital out, , the aux port will just be carrying the analog signal from your ipod.
    Rob41 likes this.
