New Budget Audio tower, that will hold Large Vintage Receivers?
Discussion in 'Listening Spaces' started by j31088, Mar 15, 2017.
  1. freQ(*)Oddio
    freQ(*)Oddio Super Member
    2,787
    Adirondacks
    I am realizing that I may not get the time to build a audio tower now, so I have looked for a plan b stand and have looked at probably 15-20 great looking stands on line, in the $400 range, from all the popular brands, most are measured across the front including the supports that are in the way , then the depth is a problem also , Sansui 9090,8080 Marantz 4400, 2250b , RTR ,2-TT, so will need 6 or 7 shelves ,need at least 24" wide shelving 18" deep, would like one large opening for RTR . probably not possible for $400, even $600. I know I cant be the only person that has had this problem.
  2. freQ(*)Oddio
    2,787
    Adirondacks
    [​IMG]close 27" wide ,if only had few more shelves and some ventilation added
  3. motorstereo
    10,320
    One of the many reasons I don't have any monster receivers anymore; those things take up lots of valuable real estate. My solution was to put the unit on the top of whatever rack I was using. Storing them was another headache and I built a custom wide storage flexi for them.
    j31088 likes this.
  4. grillebilly
    grillebilly Empty Head Subscriber
    15,350
    Fairfax VA
    Most vendors tell you what their stands are capable of holding.
    j31088 likes this.
  5. JoeESP9
    15,716
    Philadelphia PA
    How about the Pangea below? The shelves are 18" x 24". It's available at Audio Advisor @ $99. The shelves are rated for 44lbs per shelf. Add on shelves are available.
    Musicfan#51 and freQ(*)Oddio like this.
  6. E.Auer
    E.Auer Super Member
    1,687
    Lobster Pot
  7. Ross6860
    Ross6860 AK Subscriber Subscriber
    1,397
    Ohio
    I have two of these. Best bang for the buck I could find
    Now add some mortar and granite shelves to the below, on a concrete slab, and that's about as good as it gets;)
  8. KingBubba
    KingBubba "Too Much Stuff"
    9,341
    Brooksville, Fl.
    Make sure the 27" is for the inside not the outside. If it could work out, by two for the 27"ers and place them close together. I typically stack the large receivers on top and separate them using Lego Building block to keep the separation distant to allow heat to dissipate. We have a box of Legos around the house for our grandson. It is a convenient stash to snitch from as he is losing interest in Legos.
  9. tanker 200
    tanker 200 Well-Known Member
    732
    Northwest Washington
    For years I used a TV cabinet from Ikea that fit my XBR Sony TV and Sansui G-8700DB, Heating the house with a wood stove causes a lot of dust, and it's nice to keep it closed up away from the dust. I worked well but it was tough to make any changes.
    I'm now using a metal rack and like it much better, It makes changing things much easier. I think I'll stick with the rack for a while.
  10. ChuckP
    ChuckP New Member
    7
    I got one of these as I wanted a very stable isolated turntable platform. (134Lbs)
    Not as many shelves as you were needing, but its a rock.
  11. Bob in WI
    Bob in WI AK Subscriber Subscriber
    2,174
    Waukesha, Wisconsin USA
    I was looking at that too (or something awful similar). I couldn't find anyone who could give me actual useful ID of the TT compartment (the measurements ignore the struts). I moved on to another solution but I really wanted to see one like you have so I could take measurements. No one here had stock. The unit I was considering was a Bell'o. I still think the custom TT shelf is cool.
    ChuckP likes this.
  12. ChuckP
    ChuckP New Member
    7
