TubeDroid
New Member
Hi all,
A few years ago (8 or 10, maybe?) my brother-in-law GAVE (!) me a 500C (S/N 66645U) that he had hauled out of his father's console. I took it home and immediately plugged it in and put my headphones on and I was astounded at the capture and sensitivity of the FM, even in my basement and without any antenna.
I used it with the for a couple of days and considered putting it into my production system until I started to do some internet research and found out that maybe I shouldn't have plugged it in right away and I'm guess I'm lucky that I didn't blow something up.
I packed it up in a box with the thought that someday (not soon) I'd have a chance to do some restoration and mod work when both time and space permitted.
Well, two moves later that time is now, except that my bench is at the cottage and I still work for a living, so I can really only do things on the weekend, but the good thing is that I can spend the week preparing for what I want to accomplish on the weekend!
I started reading this forum a few weeks ago from it's genesis (I'm up to about Nov. 2015 so far), so I'm well versed in what needs to be done and what to avoid doing.
It looks pretty well stock, except that it seems that the Tape Monitor switch buggered up, so someone replaced it with a toggle type of switch instead of a slide switch, so it looks kind of wonky.......and the Low Filter thumb grip has broken off.......cosmetics/ergonomics come later, but I had no problem cleaning the faceplate and the extracting and cleaning the glass was a breeze; is the fact that this is a later model 500C mean that the glass isn't as fragile as the earlier models?
All the original 12AX7's are there, all West German except for two Great Britain's in the Multiplexer (V100 and V101).
Two of the original 7591A's are there (USA), and two have been changed out to a GE and Sylvania. It also came with a spare 7591A, but all it says is ROGERS on the base. New output tubes will come, hopefully after I hook this thing up to my wife's speakers
It's also rather obvious that all the switches and balance and volume tapers need a good cleaning. The power switch seems ok with good closing snap (an immediate 0 ohms when switched on, but that might not mean anything, I guess).
I do have the ubiquitous 30001-49999 Service Manual, and I did manage to get some voltage readings to compare to the schematic so I do have a (somewhat) benchmark to start with, but I don't know what the wall was giving me at the time. I just wrote these down on the schematic at the time, so most measurements at the time were rounded to the nearest volt.
7591
All Pin 6's read -16 VDC (+/- 0.2V)
All Pin 8's read 390 VDC
Pin 3's read 437/435/433/436 VDC
All Pin 5's read (ahem, short to ground for now......)
Output x-formers center tap was 441 VDC
PI
Pin 6's 139/134 VDC
Pin 8's 1.13 VDC
Pin 1's 315/321 VDC
Pin 3's 143/138 VDC
All the other 12AX7's are reading nominally (maybe max +/- 10% of the schematic values, most within 5%).
Again, these measurements were obtained years ago, the receiver's been kept in a cool dry place since.
I managed to get it on (drumroll, please) MY NEW BENCH this past weekend (after I finished assembling a variac station). I gradually turned it up over the Saturday and realized that tree frogs and other insects/birds sound suspiciously like something is going to blow, so after a couple of false alarms it went quite well, and with a jumper wire for an antenna I found that I could pull in a few stations and the stereo beacon worked (click, click) and everything.
WOOHOO!
Nothing but the tubes got overly hot to the touch, and there weren't any creaks or groans (outside of still having to listen to the ball game on AM with the other stereo.....(I know, I know...."Don't talk to me about life").
Couple of questions, nothing really technical, yet:
Am I overly optimistic that this thing will be a charm to work on? (I have the new rectifier and 7591 cathode resistors ready to go, and I'll pick up the screen grid resistors sometime this week and maybe the coupling caps and bias resistors).
This CL80 gizmo everyone talks about: I've been to two different local suppliers and I don't see anything in the thermistor department that's called a CL80. I read somewhere here that it might be referred to as NIC47D-15. Is that a vendor or manufacturers part number? I'm not sure what I should be looking for. I know I can order anything online and I could always ask a store employee, but I'm more of a "it's not the kill, but the thrill of the chase" kind of guy".
What pointers might anyone have to reduce the contortions you have to perform to work on this thing? I have it set up on an IKEA turntable so I can rotate it horizontally at will, but I can see that flipping it over to swap tubes for troubleshooting will get weary after a while, not to mention keeping the meter leads clipped to appropriate places inside. Maybe I can jig up a couple of wooden supports so I can mount it vertically on one side of the chassis; it would give me access to front, back, top, and bottom with just a spin.
Man, this thinking outside of the box is hard work.
After I shut it down yesterday for the week, I took a few pokes with a voltmeter to see what kind of charge was still being held, and after only 30 seconds or so the most I could find was about 8V from a couple of the can caps. Is this normal? I understand that the system should be routinely discharged after power down and before sticking your fingers in there. 26 years ago I built a 100W MOSFET integrated for a college project, and I built in an internal discharge system (SPST/10ohm5W resistor) just for that purpose. I was thinking of modding something similar on this thing but I don't really know the most advantageous point(s) to connect it to, or if it is even necessary.
I've also been thinking of maybe putting in an internal tone control and/or balance control by-pass system (.....'cause you GOT to build bypasses.......). Would anyone know the two most convenient points to link together. I can experiment, I guess.
Sorry if this is a long post, I just thought I'd introduce myself before I actually get down to doing anything. I'm also attaching something to this post: an upside down chassis layout view on PDF for those (like me) who find it confusing to translate the layout in the SM to what is seen when the chassis is upside down. I don't think I've run across anything like this here, and apologies if anyone else has already done this; I'll always give credit when due. Errors are entirely mine, but let me know if there's anything on it needing correction. (Think I've figured out the file upload thing here.)
Who was it that said "The reason I write long letters is because I haven't got the time to write short ones!"?
And then of course I've got this terrible pain in all the diodes down my left side.......
7591
PI
Pin 6's 139/134 VDC
Pin 8's 1.13 VDC
Pin 1's 315/321 VDC
Pin 3's 143/138 VDC
WOOHOO!
