    Dismiss Notice
New Modern Amplifiers with Pre Out and Main In
Discussion in 'Solid State' started by hearhead, May 17, 2018.
  1. hearhead
    hearhead Active Member
    208
    Are there still integrated (SS or Tube) audio only amplifiers that still sport the Preamp Out / Power Amp In function like that of the vintage Marantz Receivers?
    All I know is that the new Peachtree Audio Amps have a “Loop” in/out that functions like the above vintage receiver pre out/power in.
    Curious what I can use with my minidsp.
    Home theater amps need not be mentioned
    Here’s what I am referring to:
    https://imgur.com/gallery/hKNinCZ
  2. savatage1973
    savatage1973 Addicted Member
    6,023
    NW Pennsylvania snow belt
    Anything with a tape loop or external processor loop will be compatible with your minidsp. In fact, you are better off using in a loop than between the old-school style jumpers between the pre and amp sections, because the line-level (non-variable) signal is "stronger", so there is less potential for introducing significant noise into the signal path, and the signal being handled by the minidsp will be the same at all volume levels.
    stish likes this.
  3. hearhead
    208
    Thanks for the tape loop tip.
    Any newer post-2000s piece of gear that has this?
  4. savatage1973
    6,023
    Lots--too many to even start to list them. Just look at the specs if you find something you are considering--most will have an image of the back plate which will show a set of in and out jacks in close proximity to one another if there is a loop available.
  5. whoaru99
    whoaru99 Epic Member
    40,941
    LoTL
    One does need to check carefully though.
    Mere presence of output and input jacks doesn't, these days anyway, guarantee there is a true monitor circuit to support the loop.
  6. savatage1973
    6,023
    Quite true--that's kind of why I threw in the "check the specs/manual" thing.
  7. Powertech
    Powertech Active Member
    488
    South Wales, U.K.
    The NAD 300 series have pre out and power in connections. The pre outs, in this case, are at up to about 1 volt at full volume setting which will suit most active crossovers well. The tape loop outputs in most amplifiers are not normally amplified or buffered and will be at about the same level as the output from your source components. Note that these amps do not have a phono amplifier (even though they have a disc input) so an eternal phono preamp will be required if using a record deck.
  8. hearhead
    208
    Thanks! Now that’s what I am looking for!
