New, our $899 Transcendence 10 RB vacuum tube preamplifier.
Discussion in 'Audio by Van Alstine' started by avahifi, Feb 15, 2016.
  1. avahifi
    avahifi AK Member
    48
    Woodbury, Minnesota
    Our brand new T10 RB is an amazing evolution of our award winning Transcendence Eight series preamplifiers.
    With its newly designed mother board, we have executed significant improvements. The T10 RB mother board has separate and isolated ground panels for each section; the high voltage power supply, the low voltage power supply, and the audio circuits. This allows us to produce a very quiet vacuum tube preamp.
    The high voltage power supply features a huge pie network ahead of the four active regulators, taking supply noise and interaction down to nearly zero. In addition, there are separate regulated power supplies for the high voltage, the tube heaters, the headphone section, the optional phono section. We designed the new mother board to take advantage of the newest high capacity power supply capacitors and specify all polypropylene capacitors in the signal paths.
    The T10 RB is all tube, using 6N1P tubes in the gain stages.
    It includes the provision for an outstanding brand new split passive EQ optional phono section with its own isolated regulated power supplies.
    The end result of our efforts is a natural, engaging, dynamic, high resolution preamplifier that can interface seamlessly into and improve the most demanding audio systems.
    Eliminating many functions purists never used significantly reduced our parts cost and build labor time, allowing us to present uncompromised sonic beauty at a much lower cost than you would ever expect
    The Transcendence 10 RB has a precision volume control, a removable IEC power cord, gold plated input and output jacks and a double anodized faceplate. Also available is an optional remote control for those wanting to control the volume level from their ideal listening position.
    It has four sets of line level inputs (Line 1 used for the optional phono section if specified). It has two sets of audio outputs.
    The T10 RB preamplifier also includes, as a standard feature, an exquisite headphone amplifier.
    We present the Transcendence 10 RB preamplifier as the best we can currently do at a very affordable price. When you hear it, you will understand why we are so excited.
    The following options are available: RIAA adjustable MM/MC phono circuits ($329) and remote control with motorized volume and mute functions. ($299)
    The Transcendence Ten RB is available right now. Call us at 651-330-9871 to order.
