new project Fisher console
Discussion in 'Fisher' started by beemerbob, Feb 2, 2019.
Tags:
  1. beemerbob
    beemerbob Member
    81
    Vancouver wa
    Can i get some help with identification
    and does any one have a list of caps i need to bring back to snuff
    tks in advance
    Bob
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. notdigital
    notdigital AK Subscriber Subscriber
    2,287
    NYNY
  3. walyfd
    walyfd Well-Known Member
    735
    Northeastern PA
    1960 Executive... quite a find. There must be a story to share.
  4. larryderouin
    22,226
    Glen Burnie Md.
    Hubba-Hubba!!!!!
  5. beemerbob
    beemerbob Member
    81
    Vancouver wa
    These tone controls have me somewhat baffled do you know exactly how they work
  6. gadget73
    37,804
    Southern NJ
    They're concentric controls, a somewhat common thing on early stereo. One adjusts bass or treble in the left channel, the other does it for the right channel. Currently you have bass boost in channel A (usually left) and bass cut in channel B. They usually have enough friction that both turn at the same time. Normally I just set them so both pointers line up and treat it like a more common single knob control.
    My TA600 has these same knobs and controls.
  7. beemerbob
    beemerbob Member
    81
    Vancouver wa
    i have a power tube red plating not cherry red but still a faint red
    got a power tube red plating is there a way to set bias.....allso if iam not mistaken someone has bee
    n under the hood already
  8. gadget73
    37,804
    Southern NJ
    I'd be more inclined to suspect leaky caps than adjustment problems. I see a number of really old caps in there. The bright orange ones look more modern but I see some old Frako electrolytics and Wima "dog turds" in service.
  9. beemerbob
    beemerbob Member
    81
    Vancouver wa
    should i replace the 4 little cream colored wax coated ones and the big orange one
  10. gadget73
    37,804
    Southern NJ
    the wax ones, large orange one, the pink ones, and the can caps would be on my hit list.
  11. larryderouin
    22,226
    Glen Burnie Md.
    Any of the Dark Brown "Dog Turd" (they are marked below, at least the ones I can see) should also be replaced. There may be a couple BURIED between the chassis and the front panel, so check there too. I marked your pics with Arrows to show which caps to replace. The FRAKO e-lytics have a nasty tendency to puke out the rubber end seals. Pre-emptively replace ALL FRAKO's and DUCATI's (they may make damned good Bikes, but there vintage caps suck pasta.)
    Gadget73, you want to double check me.....
  12. gadget73
    37,804
    Southern NJ
    so yeah, basically it needs a rebuild. Looks like a couple of caps were changed, the rest are really due. I may be slightly more forgiving of the dog turds out of laziness but the rest I'd change.
    and fair warning, the tuner is going to have some of these same parts that are due for a change.
  13. walyfd
    735
    Northeastern PA
    Seriously this is an absolutely beautiful and complete unit in excellent condition. If I were you, I'd have the electronics professionally done if you can.
    The caps in the speakers should also be replaced and I see the wires for the Sony r2r which is a whole other animal.
    The amp and tuner are unique console units with very slight variations from the stand-alone units.
  14. thornev
    thornev Well-Known Member
    775
    Mid Hudson Valley, NY
    "but there vintage caps suck pasta." - Thanks for a hearty laugh, Larry. I'm a Honda man myself.
  15. beemerbob
    beemerbob Member
    81
    Vancouver wa
    thank you should i replace with like values
  16. larryderouin
    22,226
    Glen Burnie Md.
    Yes. On the lytics go up 1 or 2 voltages. for 20uf use a 22uf. 30uf use 33uf. 40uf go to 47uf. On the films take them up to 600/630V if 400V now, and 400V if 250V.
  17. PaulWC
    PaulWC Active Member
    111
    Northern Virginia
    Very nice console. What's in the drawers?
  18. larryderouin
    22,226
    Glen Burnie Md.
    Probably a Garrard RC-88 and a SONY or AMPEX R2R.
  19. beemerbob
    beemerbob Member
    81
    Vancouver wa
    triumph for me
  20. beemerbob
    beemerbob Member
    81
    Vancouver wa
    Sorry to say the prior owner removed the turntable and the recorder
