macaltec
Metal Master
This is actually my second set of Cornwalls. Had my Dad pick them up for me in NY, Im in NC. All I have is pics for now as they are 10 hours drive away. S/N is 19Txxx (79's) on both and roughly 50 units difference between them. I have a few concerns. First the tweeters, they obviously don't match. Which one is original which is the replacement? How much difference in age is there between them? Second, from the pics only can anyone shed some light on the crossovers? Do they look unmolested/intact excepting the obvious new wire? The added drivers are not hooked up, they will be removed, should I patch the holes up, make a new baffle, or make some sort of CornScalla project with them? If I make a project I have Heresy I cabinets that could receive the tweeters and midranges. The back will also need some attention with new/better plywood and and a modern terminal cup. Depending on whether I leave them "original" or make a project out of them the crossover will at minimum get a Crites recap. Opinions/suggestions please. Thanks.
