JosephH
Super Member
View attachment 1118542 View attachment 1118542 View attachment 1118542 View attachment 1118544 View attachment 1118545
I took on a 950 mile journey Saturday to pick up a nice MC 2205. The unit is in very good shape, the chassis polished up nicely, no rust, all silk screening in place. It proudly displays a McIntosh Performance Clinic sticker from 1986, with the initials DOB inscribed. According to the PO, it had not seen use in at least 5 years, having been put on the bench by a large Threshold amp. Once I placed it into service, a couple issues popped up. The Power Guard lights would go on at very low volume and it heated up immediately. I verified that I had switched it to mono, but upon exercising the stereo/mono switch a few times, operation returned to normal. Sonically it is a real powerhouse, lots of punch and clean power. Temperature immediately returned to normal as well. The only other issue was the meter lights would vary in brightness. They would dim and them return to full brightness. The flickering was not volume driven as it occurred at any volume level. As the hours passed the flickering lessened and stopped. Is this anything to be concerned about? I am guessing a power supply board problem?
In addition another issue surfaced as well. I immediately noticed output to one speaker was much lower. The channel being driven by my original MC2205 had much lower output. I changed sources and then flipped the speakers and the problem stayed with my original MC2205. The output is still very clean, but much lower. To equalize the channels, I had to run the gain knob on the new 2205 at about 1 o'clock with the original amp gain on full. Seems like both amps might need a trip to Audio Classics. Thoughts?
Anyhow, here are some pics, I have since polished the chassis with Wenol and removed the front bezel which was falling off anyhow. It sparkles now....
