Thehardway
New Member
Hi, first post, have always been interested in vintage audio stuff but never found the time for it, but recently I had the unfortunate circumstances to pick up one of these units, (death in the family), along with with some other pieces to go with it.
Ive hooked up this receiver to make sure it works and it seems everything does but Im a total noob when it comes to these things. The inside is DIRTY, really dusty so I do need to clean it, but my questions are, I cant seem to get a good signal on it with FM, well I can get a good signal, but the volume is really low if I have the clip from the power cord on the antenna, I have also tried hooking up an old cable wire I had laying around to the 75 ohm connection, but it seems the connection inside is loose or something, it barely wiggles, but playing with it only gets me static, and again, low volume. If Im one notch lower or higher on the channel I need the volume gets to where I think it should be but of course because its not the right channel its static. So basically it feels like nothing I do for the antenna will pull in any channels. I know theres probably more issues but Ill ask them later after I get this working correctly. Any ideas on where to start with this issue? Thanks
