Noahpdavis
New Member
I had a post in the Solid State section and it was suggested that I post something here.
Wanted to run my parts list by you guys to see if you had any notes/suggestions. I was going to use the Panasonic FC Series capacitors and order everything from Mouser.
Am I missing any? Will these fit? It seems hard to find replacement axials in the correct values, so I guess people just use radials and bend the leads to fit?
My main hope is to replace the ones that will theoretically improve the sound.
If anyone has a parts numbers list they've successfully installed that they could share I'd really appreciate it.
C1,2 Mylar ,22uF 250V - not replacing
C3,4 Mylar .47uF 250V - not replacing
C5,6 Elect. 500uF 16V - replace with 560uf - 16vdc
C9,10 Elect. l0uF 25V NP - replace with 10uf 25vdc
C11,12 Elect. 100uF 15V - replace with 100uf 16vdc
C101,102 Elect. 330uF 3V - replace with 330uf 6.3vdc
C121,122 Elect. 10uF 50V - replace with 10uf 50v
C201,202 Mylar ..47uF 250V - not replacing
C203,204 Elect. 100uF 3V - replace with 100uf 6.3vcd
Any help/advice you have is much appreciated. I've done some recapping of pinball machine sound boards, and suppliers sell kits with all the caps/values you need to upgrade, which is very handy . This make your own kit thing is a bit confusing - ha.
Thanks!
Thanks!
