Finally getting back to this after an employment change...
So, in a nutshell, you're suggesting a cathode follower to allow for long cables and/or use with a SS amp?
Well, I've always believed in making my signal path as simple as possible, and not adding any elements not explicitly needed. I have noticed that a previous pre amp build does have some issues with very long interconnects, but the intended use is only with tube amps and only with interconnects of 3' or less.
Here's the current schematic...
Untitled by
Allan Shang, on Flickr
and the DC filament supply....
Untitled by
I've been over the schematic with Dennis Had, and he thinks it will work fine, although he's not a fan of the 01A since he thinks it's typically pretty microphonic.
Guess we'll find out.
Also, I decided to go all in on this build, so Tony, Dennis' set up man for the Inspire gear not only drew out, drilled, and pre - populated the chassis, he also talked me into a revolutionary concept for a home built tube amp, a remote control for the volume pot. The two black boxes snuggled up to the left underside of the chassis are the additional electronics to run the volume pot, and the little key fob is the remote. What a concept! Dennis was kind enough to throw the chassis in with a bunch of his at the powder coater, so it's also professionally powder coated.
by
Untitled by
Untitled by
The little dongle on the back is the antenna for the remote.
Untitled by
The underside ready for soldering!!!
Untitled by
I've got a lot on my plate right now, so it may be a few weeks before I can get much done on this. I suppose I should take a few minutes and make sure I have all the necessary parts on hand...
