EvanF
AK Member
I checked the voltage on the pins to the relay coil.It's 59+ VDC, the power supply rails voltage. What can be failing to cause this? The amp was working fine until the relay shut off. I changed the reservoir caps and 3 of the relay board caps. I see no damage on any part, it smells fine.
