First and foremost...hello to all! First post and all...
I've decided I needed to make my life more complicated and full of disappointments so I've started buying vintage amps. My first foray into this world is a very clean Nikko TRM-1200.
Everything mostly works and I've gotten rid of some minor issues by cleaning the pots but one major issue remains. When turning on the amp, there is a loud POP on the right output and the vu meter spikes monetarily. During playback, audio is distorted on that channel but only on that channel.
I should also note that when using the Nikko as a pre-amp, everything is perfect...no distortion.
I'm a novice so I could use some guidance...where do I start? Has anyone had this particular issue with this amp? Thanks for your time!
