Greetings from RojoLand!
Recapping the playback amp card is worthwhile. The transistors are all PNP germaniums and can be noise sources. Old 'lytics in the signal path have potential to upset bias voltages and cause circuit havoc. As you surmised, changing to silicon PNPs will require some bias resistor changes. My A-4010S does exhibit a tiny bit of hiss (but is quite un-noticeable when playing a tape), so I built up a part of the playback amp circuit on my breadboard using PNP Si transistors, and got it to work well, so it *can* be done in theory. It's just a matter of finding the proper biasing resistors (and choosing nice quiet transistors). The goal, in my mind, would be to get the circuit to work with just part changes, not a change in circuitry (requiring alteration of the PC board). Staying with PNP is a better plan as well.
Hi J. E. (and everybody else),
I've been listening to tapes, and had forgotten just how bad the hiss/windy noise was from my A-4010S.
So I'm thinking more about replacing the Ge transistors with Si. The SM has a very convenient "DC version" of the schematic:
It looks like (apart from hair-splitting) all of the quiescent voltages are independent of Vbe, so there really shouldn't be any changes required to the resistor values to switch from Ge to Si. Do you agree? That would make this a much easier project!
The next question is
which Si transistors to use. Do you have any suggestions? As well as my eyesight can tell, the original ones are:
Q1, Q2: 2SB486 (Pc = 0.12 W, hfe > 200, ft 3 MHz, Ic max 0.05 A)
Q3: 2SA49 (Pc = 0.06 W, hfe > 30, ft 5 MHz, Ic max 0.005 A)
Q4: 2SB189 (Pc = 0.25 W, hfe > 70, ft 0.5 MHz, Ic max 0.25 A)
(and the capacitance multiplier)
Q9: 2SB415 (Pc = 0.20 W, hfe > 70, ft 0.4 MHz, Ic max 1 A)
I don't have much experience in choosing replacements, but based on some web surfing and convenience (what I have on hand...) I was thinking of:
Q1, Q2, Q3 -> KSA992 (Pd = 0.5 W, hfe > 150, ft 100 MHz, Ic max .05 A)
Q4 -> 2N3906 (Pd= 0.625 W, hfe > 100, ft 250 MHz, Ic max 0.2 A)
Q9 -> ZTX790A (Pd = 1W, hfe > 300, ft 100 MHz, Ic max 2A, Vce 40V)
I wasn't able to find any info at all about the noise performance of the Ge parts. Comparing noise specs is tricky, but I just assume that the KSA992 (an "audio-frequency low noise amplifier") is a good choice. And since Q4 is the final gain stage I assume that it's noise performance isn't as critical. The ZTX part for Q9 I just picked using Digikey filters.
The two issues I see with these choices:
1) Ic max of the 2N3906 is 200 mA. But in this application (2.2k collector load) it will never get close to that.
2) ft of all the Si transistors is much higher. I've heard of people adding caps from C to E to prevent oscillation, but I't rather not modify the circuit board. (Maybe add them "dead bug" style if needed?)
rojoknox, do you remember what Si transistors you used on your protoboard experiment? Did you have any oscillation issues?
I'm not committing to a plan, but right now I'm thinking of...
1) replace the 10 uF coupling caps, listen to sound.
2) replace the other ecaps, listen.
3) replace Q1, listen. And look at output on scope for oscillation. And keep the original part.
4) ditto Q2
5) ditto Q3.
6) ditto Q4.
I didn't mention anything about resistors b/c I don't have a supply of metal film resistors. If all goes well, I'll make up an order and swap those out as well.
Ideas, comments, face palms ?
FWIW, here's the complete schematic.
