Noob capacitor question
Discussion in 'DIY' started by cabby, Feb 10, 2018.
  1. cabby
    cabby Active Member
    152
    I'm getting ready to refoam a pair of old Acoustics Research speakers. While in there, I took a peak at the crossovers. It looks like the capacitor is soldered on directly to the mini circuit board. It doesn't have the two leads coming out on either side like commonly seen, but rather two leads on same side soldered on to board.
    1. First of all, I'll assume 3 MFD is same as 3 uF.
    2. What type of capacitor is this, and where do I find a pair ?
    THanks !
    Cabs
  2. Blue Shadow
    22,328
    SE PA
    yup, electrolytic 3µF 50V.
    Go to parts-express and get a pair of Dayton Audio or Solen Metallized Polypropylene caps for a few bucks a pop. They sound better than electrolytic. Higher voltage is ok.
  3. N8Nagel
    6,923
    Rockville, MD
    What he said. Cap you get will probably be axial, no problem, just set one lead in the hole, put spaghetti over the other lead, make it fit.
  4. cabby
    cabby Active Member
    152
    OK got it! the orientation of lead doesn't matter as long as the leads are soldered on !:banana:
    thanks gentlemen.
  5. JMiP
    JMiP AK Subscriber Subscriber
    334
    North Carolina
    How do you remove that gluey stuff that seems to be holding the capacitor to the resistor? And do you have to replace that gluey stuff when the new parts are in place?
  6. steveUK
    steveUK Well-Known Member
    512
    Midlands, UK.
    It's just a silicon type substance, or hot glue gun glue. Pull and prise it off with your fingers or tools, whatever, just be careful not to slip. You don't really have to replace it, it's a 'belt and braces' approach to robustness and reliability by the manufacturer so as to limit the possibility of the component leg breaking if exposed to high vibration levels. I've just recapped the crossovers on a Realistic Mach 2 speakers and they weren't glued in place, and that speaker is a window shatterer. If you pull the legs down through the PCB nice and taught (not enough to break them or do damage) you should be ok, but if in doubt, apply hot glue or silicon to hold it in place.
