Noresco NC-1010 Tube Phonograph Fix it ?
Discussion in 'Tube Audio' started by CavScout, Nov 23, 2016.
  1. CavScout
    CavScout Active Member
    385
    I have aquired an old Turntable with built in amp.
    It needs a little bit of servicing but it works.
    The 2 speaker outputs on the back
    are homemade by an unknown previous owner.
    It puts out almost no sound when 2 speakers are hooked up.
    When one speaker is removed the audio gets much louder but still not very loud.
    So I opened it up and to my surprise there was a tube amp inside.
    I am handy with tools and a soldering iron but I know nothing about tube technology.
    Is this worth fixing ?
  2. century tek
    century tek Super Member
    2,955
    The Evergreen State
  3. larryderouin
    21,228
    Glen Burnie Md.
  4. CavScout
    385
    Here are some pics
  5. larryderouin
    21,228
    Glen Burnie Md.
    There isn't too much to replace in the amp. Maybe a few caps (including the CAN), possibly a few resistors, and 3 tubes. 12ax7 and 2 6bq5's??? If so about 4-5watts per channel. It could quite possibly have had RCA jacks for speaker output's originally.
    Can you verify the tubes? The amplifier should come out from the inside after removing the knobs, then a couple of nuts on the front panel. Find someone local who has a tube tester or if you have an amp or receiver that uses the same tube #'s, swap those tubes in and compare with the pulled tubes.
  6. CavScout
    385
    I have decided to sell it. It is pretty cool but I already have a turntable.
    I am amazed at the quality of the cabinet and the heavy duty lid with real thick smoked plexi
  7. cademan
    cademan Addicted Member
    8,800
    Wow! Pics a year later. :D
    Simple little hot chassis design. I'm guessing 50C5 and 12AX7 are the tubes. It probably needs a general recap to bring it back to life and since it is a series string chassis, it would be safe to operate in its original cabinet and setting.
  8. knockbill
    knockbill Addicted Member
    7,117
    SE PA
    I agree... can see 50xx on one of the tubes...
  9. larryderouin
    21,228
    Glen Burnie Md.
    If thats (50C5)the case, 2 to 2.3W per channel.
  10. primosounds
    primosounds Parallel single ended EL84 ,EDCOR OPT
    2,017
    Terra, 21st century CE
    Dammmnnn. did Kodak lose your photos from developing and just sent them back to you?
    HiFi in WYO likes this.
  11. HiFi in WYO
    HiFi in WYO The universe is a big place, perhaps the biggest. Subscriber
    2,456
    Wyoming
    The Fotomat closed ... :thumbsdown:
  12. primosounds
    2,017
    Who knows, film developed photos may enjoy a revival like vacuum tubes!
