Now it's time to ...
Discussion in 'Yamaha' started by amr2, Mar 20, 2018.
  1. amr2
    amr2 Well-Known Member
    581
  2. Blue Shadow
    22,255
    SE PA
    looks like some serious cleaning and detailing on those units before it is time to do much of anything. Enjoy getting intimate with your new amps.
  3. BOUXY
    BOUXY Super Member
    4,682
    WPG,MB CANADA
    Clean clean and then some more CLEAN:)
  4. amr2
    581
    Yes. It needs a lot of cleaning! I’m going to restore them as best I can. ;)
    rottalpha likes this.
  5. parman
    parman vintage rocker Subscriber
    6,826
    worse than Detroit
    NICE!!!!
  6. rottalpha
    rottalpha Yamaholic Subscriber
    1,856
    Middle of Crook County
    amr2 likes this.
  7. amr2
    581
    I'm going to add a speaker protection module inside. Something compact that can be added elegantly.
  8. SoCal Sam
    SoCal Sam Lunatic Member
    19,275
    Picker's Paradise
    P2200's!!
  9. bmanone
    bmanone Active Member
    145
    Calico Rock, Arkansas
    amr2,
    I've repaired and refurbished two P2200s, one had a intermittent popping sound after the repair. Traced the problem down to some counterfeit transistors (tested OK on the cheap transistor tester), see picture below. Both of my P2200s sound really good, they are my favorites. I didn't add speaker protection, but I did a couple of 2 amp inline fuses to my speaker cable, I hope it's enough protection. Looking forward to seeing what you do for speaker protection. counterfeit.jpg
  10. amr2
    581
    counterfeits....:no: A couple of weeks ago I repaired an amplifier, somone tried to repair it before. And I found this:
    BF245A, N-channel silicon field-effect transistor:
    About the protection, I already have the modules, one per channel. I'll put them next to the output connectors, reversibly and without modifying the chassis. I hope to upload some pics soon.
  11. asdf_x2
    asdf_x2 Active Member
    170
    Finland
    I'm also looking forward to seeing your protection circuit placement. I just recently got a P2201 (a P2200 without the meters) and have been wondering how to retrofit a DC protection/delay circuit in it.
  12. Mrvintage
    Mrvintage AK Subscriber Subscriber
    64
    Parry Sound Ontario Canada
    Good evening
    I have a complete 22 page service manual for P2200 if that will help in your Yamaha project. I have 3 P-2200 I’m building a vintage system with
  13. amr2
    581
    The speaker protección modules. One for each channel
  14. bmanone
    145
  15. amr2
    581
  16. bmanone
    145
    I saw that unit when I was looking, I think it'll work great. Do you know how much current it'll draw? Do you plan to use an inline fuse? I thought about using the BE lines, I was just a bit concerned about the current draw (should be small though, relay coil draws 77mA) and injecting noise into the amplification stage.
  17. amr2
    581
    I have to check it, but I think the current draw should be low, less than 100mA, and noise shouldn’t be a problem.
    I did not plan to use an inline fuse.
  18. bmanone
    145
    Installed my speaker protection boards yesterday, I ended up using BE (13V. AC) to power the modules. Here are some pictures of right side installation (left side was complete first).
    Speaker Protection Board
    Locating the Board
    Mounting holes drilled and tapped
    Rubber insulator sheet
    Screws and spacers in place on board
    Board Mounted
    Board wired
    Board wired to speaker terminals, BE ac power, and right amplifier board
    Protection Board installed showing clearance to amp board
    The P2200 works great with the protection board installed. No more turn-on pop, no more playing on after the unit is powered off, and lastly no more worry about excessive dc offset causing speaker damage. This board does not protect the amplifier from dead shorts across the speaker terminals.
    asdf_x2, Bratwurst7s, amr2 and 3 others like this.
  19. amr2
    581
    Excelent work Barry! This is how I plan to place the modules.
    BTW, what capacitors have you used to recap the boards? Panasonic FC?
  20. bmanone
    145
    Alberto,
    Thanks, I used Panasonic FC's:
    4 x P10352-ND EEU-FC1J471 CAP ALUM 470UF 20% 63V RADIAL
    4 x P10301-ND EEU-FC1V471 CAP ALUM 470UF 20% 35V RADIAL​
    Vishay axial:
    2 x 4245PHBK-ND MAL213818221E3 CAP ALUM 220UF 20% 63V AXIAL​
    EPCOS (TDK) Film:
    2 x 495-5047-1-ND B32529C0474J189 CAP FILM 0.47UF 5% 63VDC RADIAL​
    Nichicon Aluminum Poly:
    2 x 493-3711-ND RR71A101MDN1 CAP ALUM POLY 100UF 20% 10V T/H​
    I also replaced the common anode and common cathode diode arrays with these Schottky types:
    2 x 1655-1098-ND MBRF10150CTR DIODE ARRAY SCHOTTKY 150V ITO220
    2 x 1655-1097-ND MBRF10150CT DIODE ARRAY SCHOTTKY 150V ITO220​
    I had 3 of 4 (D114 and D115) diode arrays fail on one of my P2200s. These SCHOTTKY diodes have the added benefit of a lower voltage drop to rectify BE, offsetting the voltage drop cause by the speaker protection boards!
    Hope this helps with your project!
    Barry
