Ray Gianelli
Super Member
Recently picked up an MX-1000 that was sold as non-working. Popped it up on the bench and nothing when powered up on the DBT. Opening it I found both 10 amp power fuses blown (!). The 7 amp fuses on the power supply board were fine.
The only failures I could find were a shorted NPN output on each channel. It's uncommon to find both channels bad IME, but to make it stranger was the fact that this is all I could find; emitter resistors were all good, base resistors as well. In fact I can't find anything else that checks bad.
Am I missing something here? I'm used to major carnage from failures in direct coupled amps. Hell, the last M-80 I had on the bench had one channel that was toast from the outputs damn near to the input. That said, I don't specialize in any particular brand. So I'm posting here in the Yamaha forum in the hopes that someone can chime in. I'm still replacing all the outputs, but I'm not doing so until I'm absolutely sure there's nothing else wrong.
Thanks!
Oh, and I found lots of cracked solder joints on the main board and fixed them. Also replaced C517/518 100uF 6.3V caps, as one read nothing and the other had an ESR of 13 ohms.
Thanks!
