Hi folks. I have an SX-737 that I am rebuilding. When I got it, it was filthy and was missing one of the output transistors. I replaced that with a new MJ21194G. I rebuilt the entire amp board--all new transistors and new electrolytics. I was pretty careful with polarity. I have replaced all the blue Sanyo caps except in the tuner board so far, and I replaced all the transistors in the preamp board. I redid the power supply entirely--all new electrolytics, transistors, and diodes. I replaced a few transistors and caps in the protection board. I have not added the diode mod or replaced the relay yet.
I cleaned and lubed the controls with Deoxit and Faderlube.
So, it plays fine and sounds good, BUT I have some issues.
1. I cannot get the bias down below 50mv on the left channel.
2. I cannot get the DC offset below 0.25v on both channels.
3. I get a decent amount of FM playing on the right channel on the Aux input, when I turn up the volume.
4. FM radio will not completely go silent when I turn the volume all the way down.
I took it off the dim-bulb and found that power supply voltages increased, but it still has the issues. I am using the updated bias/DC offset instructions found here. I know the service manual is incorrect on this.
Power supply voltages are:
1. zero
2. zero
3. fluctuates around -.6
4. fluctuates around -.6
5. zero
6. fluctuates around -.025
7. -38
8. zero
9. 35.3
10 .-35.64
11. fluctuates around -.03
12. -11.5
13. -11.5
14. 35.16
15. 26.9
16. 27.05
17. 4.5
18. zero
19. 13
20. 13
21. 13
1. zero
2. zero
5. zero
7. -38
8. zero
9. 35.3
10 .-35.64
12. -11.5
13. -11.5
14. 35.16
15. 26.9
16. 27.05
17. 4.5
18. zero
19. 13
20. 13
21. 13
