Ok,the 5 conductor Humbuckers came...how do I wire them?
Discussion in 'Musical Instruments' started by philo426, Apr 7, 2018.
  1. philo426
    philo426 Super Member
    2,548
    Ok the upgraded Humbuckers came in for my Harley Benton HB35 335 copy.Already put Grovers on,so do I remove the pots from the F holes?What if the stock pick ups are 2 conductor?I will not coil tap them so how do I wire them up?Plus I dont like the input jack on the side,messes up the settings on Vox mini amp.I was thinking of relocating the input jack to the front like on an Epi Dot and leaving the old one on the side disconnectedl
  2. valvenator
    valvenator curious bystander, serious procrastinator
    No instructions with the pickup?
    By 5 conductor do you mean 4 colored wires plus a ground?
    Maybe a pic of the wires could help.
    What pickup did you get BTW? Sometimes you can find instructions online.
    If you know what wire goes where it's pretty easy to figure out.
  3. Rockon1
    Rockon1 Well-Known Member
    586
    What pick up's? The color coding isnt standardized between various aftermarket pups. If the originals are two wire that means the coils were most likely connected in series. 4 wires (the "5th" is ground like valvenator mentioned) just gives you options- series (pretty much standard HB wiring) , parallel or split. To make it series you just need to know which wires are which coils and the start and finish for each. The info is out there just google it for your new pup.
    On my hollowbody the originals were two wire. I wired the new pups for series and spliced them into the original wiring. Bob
  4. philo426
    2,548
    No instructions in the box,but five conductor Dragon Fire Humbuckersl 15233267186721543933245.jpg 15233267186721543933245.jpg
  5. philo426
    2,548
    Ok!missed an e-mail the seller sent with wiring instructions.Green is positive,North Start(What does that mean?)Black is negative South Start,Bare wire is the ground.Red wire is North finish white wire is South finish.
  6. valvenator
    Sorry, the picture just isn't clear enough to make out the wiring but it looks like two of the colored wires are soldered together.
    Those would simply be covered with tape for insulation. If one of the wires is soldered to the ground wire that's where it would go.
    The other free wire would be your hot input. Like i said though I can't really tell from the pic so I'm just making a guess.
  7. valvenator
    Just missed your post. Are any wires soldered together?
    I've wired quite a number of pickups but it's not something I do all the time so I have to give myself a little refresher course when I do so it's kinda hard to give you answers off the top of my head.
    Plus as Rockon1 stated "The color coding isn't standardized between various aftermarket pups."
    ...which doesn't make it any easier.
  8. philo426
    2,548
    Yes the red and white are soldered together.
  9. valvenator
    Well for a start those wires would be insulated and left alone for standard series wiring.
    I don't think it matters which of the other two you use for hot and ground as long as you do both the same if you want the two pickups in phase.
    ...though I would think the green start wire would go to the hot input and the black to ground along with the bare ground wire.
  10. philo426
    2,548
    ok so it us ok for the red and white wires to be connected just taped off?
  11. valvenator
  12. philo426
    2,548
    Ok thanks for the help!
