I'll tell you, I'm seemingly experiencing the same thing, in two different systems I have! I have a likely explanation for my "office" system...maybe for my "main living room" system too?
1) Main living room - Digital sources (Nvidia Shield, Roku 3, DVD player) -> Monoprice HDMI switcher (digital coax out) -> Peachtree Decco 2 integrated/DAC -> KEF 103.2 speakers/sub.
So in this system, for the longest time I only needed about 9 o-clock on the dial MAX. Suddenly I needed to go to 12:00 - 1:00 for the same volume. Speakers were recently re-capped in this system. Not sure what's going on, other than maybe caps breaking in? Anyway, now it's back to only needing 8-9 o-clock on the dial. Weird!
2) Office system - PC/turntable -> Juicy Blueberry pre -> Monarchy SM 70 amp -> Quad 57 speakers/sub. All plugged into voltage regulator and power conditioner.
I think in this system, it could be one of a few things. I need to fiddle with balance controls a lot. Also suddenly the system became quite BOOMY, where I needed to turn the subwoofer way down from its previous setting, where I had it for several months and it sounded "good."
Possibilities?
- bad tube in preamp? Pre was making noise, in its previous system, which is why I moved it. Not getting the noise any longer, but now getting a mild distortion, noticeable during quiet passages...and then the sudden weird change with the "boomy" bass. I plan on trying a different preamp here. If the new preamp improves thing, changing a tube in the Blueberry should do the trick I think.
- Quad speakers finally showing issues and needing some work. They are "closet queens," not restored. I've been using them around 9 months, 5 days per week. I suspect they would benefit from a power supply rebuild.
- Power conditioner or voltage regulator causing issues.
- 2 of the speaker cables I'm using are about 15 years old. Not likely causing the issue, I don't think, but need to change these! Plus I tripped on one of them shortly before this happened. I did check the connections, but I need to get some new cables in place. Planning on some Monoprice for now, since that's what I have available. Would like to get some Morrow.
- Other?
So just wanted to lend my "support" here and say I've experienced the same thing!
