One channel comes up first
Discussion in 'Tube Audio' started by CopperWizard, Aug 11, 2018.
  1. CopperWizard
    CopperWizard Well-Known Member
    888
    Eugene, OR
    I have a Magnavox 8601-20 amp where after power is applied, the left channel comes up first from the speaker, then 2 seconds later the right channel. Everything sounds great. Just wondering if this is normal and why?
  2. s-petersen
    s-petersen Scott Subscriber
    4,784
    Middletown,New York
    Try swapping tubes, it could be normal as some tubes take a little longer.
    CopperWizard likes this.
  3. primosounds
    2,999
    Terra, 21st century CE
    Yeah, i agree with SP, seems like a tube issue. Could be a noisy tube is making itself known ahead of the others.
  4. thorpej
    thorpej AK Subscriber Subscriber
    1,674
    San Francisco, CA
    ...or one of the power tubes is weak and it's cathode doesn't start emitting until it's almost completely warmed up. If it's not one of the output tubes, it could be a weak side in the voltage amp tube as well.
  5. Dave451
    Dave451 AK Subscriber Subscriber
    1,298
    Philly area
    Had the same thing happen with a couple of voltage/tone control 12AX7's. Both new production. One was a little 'colder blooded' than the other and came up to volume a couple seconds slower, but after that all was fine. Wouldn't worry about it if it were mine unless there are uneven levels side-to-side after warmup or any noise.
  6. CopperWizard
    888
    Eugene, OR
    Update: I switched the power tubes around and it followed the tube. They were both tested recently and were at 80%. They are Sylvania black plate 6bq5. I'm not going to worry about it as Dave suggested. Thanks for the replies fellow AKer's!
  7. GordonW
    17,988
    Marietta/Moultrie GA USA
    If it was more than 10 seconds differential, I'd be concerned about a weak or dying tube.
    2 seconds is completely within the realm of "absolutely normal".
    Regards,
    Gordon.
    Celt likes this.
