camgilbert
Member
Hello,
I have a luxman fq-990 which as the left channel and right channel amplification on separate boards that are interchangeable.
The right channel is working perfectly but the left channel is low and pops slightly as you turn the volume up.
The volume pot has a left and a right so balance is handled with that.
I swapped the two amplifier modules and the problem persisted on the left channel and through headphones.
Other then the volume pot and eq board is there any other place i should look to troubleshoot the issue?
Schematic online is very bad.
Many thanks in advance.
