OnePlus Bullets 2T earphones continues the design adopted by the first generation of bullets earphones. The main body of the earphone is made of metal and is sprayed with 205 zircon sand. It is anodized twice to make sure that the earphones have a better texture. The wire makes less easy to knot and wrap and has a wire control function. Aramid fiber is also added to the wire to make it more durable. OnePlus Bullets 2T Earphones has a built-in independent DAC digital decoder, which supports 96KHz/24Bit high-definition audio format, can provide better quality sound from its aluminum alloy sound cavity. The most important thing is that a OnePlus Bullets 2T uses a Type-C interface instead of the traditional 3.5mm headphone jack.
Product Features:
● Crafted a listening experience that's immersive, vibrant, and extraordinarily detailed, thanks to an advanced internal DAC with high-res audio support.
● Fitted with a high-quality film diaphragm that makes voices sound more realistic and immediate.
● The flat-wire cables are tangle-free and threaded with tough Karbon fiber.
● No need to take out your phone every time you want to pause a song or answer a call, that's what the three-button in-line remote control is for.
● The left and right channels reproduce sound independently, reducing noise and capturing each note perfectly.
● By removing the MIC signal from the channels, the quality of your phone calls is significantly improved.
● Traits like temperature resistance and plug durability are all put to the test, and only the earbuds that emerge from the tests in pristine condition are good enough for your ears.
● Perfectly compatible with OnePlus 6T.
The Bullets 2T are extra-lightweight at just 1.8 grams, they're made with an aluminum alloy sound chamber, which does not have any negative sides while greatly reducing cavity resonance which causes distortion of sound: https://gearvita.com/oneplus-bullets-2t-type-c-wired-earphones.html
You may also like:
cheap qcy t1c mini wireless earphones
cheap huawei CP60 wireless charger
Product Features:
You may also like:
