Hi all;
Got a nice Onkyo M504 that the Speaker 2 Switch (S702) will not keep contact to keep the relay tripped so I am getting intermittent output on Speaker 2 outputs. Speaker 1 works fine. I ohm'd out the switch and seems the problem is there because keeps opening even without power applied to unit. I was able to get some deoxit into it followed by fader lube and seemed to solve the problem. But by time all back together and a day later, same thing occurring just not as bad but still intermittent unless hit it several times.
Wondering if I should keep hitting it or try to replace? Does not look like comes apart like some of the older switched. It's a small black box.
SM calls out NPS-222, L506 as description. But nothing else and don't get hits on google search our Mouser.
Anyone ever replaced this switch?
