riverrat
professional camper
My "new" Onkyo T-9 arrived yesterday.
I'm curious how many lights this unit has for the tuning dial display. I see only one lit up on mine- it is attached to the tuning pointer and follows it along as you turn the tuning dial.
Are the signal strength and tuning meters supposed to be lit as well?
Also, the tuner came with a hang tag that says:
"Note regarding TUNED lamp:
Touching the tuning knob when receiver is in a tuned state will cause the tuned lamp to go off. If the tuned lamp does not go off readily, it may be adjusted with the sensor switch on the rear panel, which has settings for LOW, NORMAL and HIGH sensitivity. For further details see Instruction Manual."
I don't have the instruction manual, so I am curious what the purpose of this feature is.
Thanks for any advice from T-9 owners!
