You have another posting asking about bias and offset. So I'm answering it here as best to leave all on one thread.
SM shows the test point on adjacent left schema. My advice is don't mess with adjustments as if you missed the notes that unless you replaced any transistors. Basically no need to. Nothing wrong with putting dmm on mv (NOT ma) and I highly recommend you assure that you don't short them by using probe clamp shielded or shielded test cable. Quality of adjustment pots is important but usually set and you get a good reading, playing with the pot to see what happens may risk blowing a driver transistor.
I'm saying its best to get an overall picture of health before screwing around. Those mains caps may be perfectly good and how do you know they're 'past' their life expectancy when you don't even know what the ct test points are? Or own a cap tester? What you should do is be checking the 'BASIC' voltages noted for the various transistors. On the schema they are bited in the rectangular boxes. + this - that. 0v etc. If all those are within even a mv it's good to go. even if a couple mv's isn't necessarily a concern if the other side +/- transistor is close, too. You can have variance at idle it's when the transistors start kicking what counts and circuit v's can vary.
Now the mains caps my be fine but you may have lower v caps that need replacing or reforming. You can post close up pics and we can usually identify shrink. 15v rated caps ought to go. again post pics. Be surprised how many caps can reform.
bink
