AndyPrice44
Hello,
Well, I got home from work today and my receiver was screwed up. We had some thunderstorms in Kentucky this morning and I assume I had a power surge of some type. When I powered the unit up it would pass a video signal and I was getting a picture but, I couldn't get sound on any source. I tried power cycling all my equipment and still no good. I tried switching inputs and still didn't work.
I did a quick google search and it appears that this is a known bug with these onkyo receivers. There was page after page about this problem. This is my fourth onkyo unit and for the most part they have been good units. I did have my display screen go out on my last unit and now my current unit has developed a problem with the sound dropping out today. This is the first time it has happened and I wasn't getting sound out of any of the seven channels or subwoofer.
After reading many threads, one common theme presented itself. There is a problem with the HDMI board. More specifically a problem with the DTS chip loacated on the HDMI board. I don't know why onkyo designed the unit this way but, the power for the amp section is passed through this DTS chip. If the chip is malfuntioning, you don't get power to the amps and thus no sound. If you have this problem, you will notice that the speaker icons that you usually see in the top left corner of the display are gone. Another sign when powering up is that you don't hear that second click of the power relay feeding the amp section. Whenever you power on an onkyo unit, you usually hear two distinct clicks. I was only hearing one.
I was reading and trying to figure out a way to solve this problem and came across a few threads about applying heat to the DTS chip. Some people said to use a halogen bulb. Another said to use a hair dryer. One thread even went as far as to recommend putting the whole unit in the oven on low heat. (seriously...) This seemed counter productive to me as we all know that heat is the enemy of all electronics. Manufacturers go to great lengths to dissipate and remove heat from the inside of these units with heat sinks and fans. Why would adding more heat to the unit manage to solve anything?
I also watched a few youtube videos claiming to fix onkyo units with the methods described above. Only two of them worked. One guy put a halogen bulb directly over the DTS chip for about 40 seconds and power was restored to the amps.
Another guy used a hair dryer aimlessly on the whole HDMI board and after three long and boring attempts, it started working again.
I decided that the hair dryer was the method that had the least amount of risk involved and I decided to give it a try but, instead of blowing hot air all over the place I would just concentrate on the DTS chip.
I located the DTS chip on the right rear of the HDMI board and concentrated the heat in this area. I used high heat and low fan speed. I kept using the hair dryer on the chip for about 90 seconds total.
HOLY SHIT IT WORKED!! I couldn't believe it. I am now getting sound back on all channels again. It has been working for about three hours now. I know this isn't a permanent fix but, at least I can watch TV tonight. Other owners of this unit mentioned that onkyo will replace the whole HDMI board if you send your unit in. I am going to have to check to see if they will still do this on out of warranty units because mine is past it's prime. I am also going to see if I can purchase just the HDMI board and replace it myself. I will update this thread at a later date with my findings. I just wanted to document this on the forum for others to see because I'm sure someone will have this problem in the future.
Andy
Andy
