Here is a rare bird, an Optonica SM-4000 amplifier that I'm looking at for a fellow AK'er. Solid construction, the thing weighs a ton, with a big transformer, 2 x 15000uF of power supply regulation, and two big heatsinks.
Only thing is, it won't come out of protection. I measured the offsets, the right amp board has 405mV :worried:, but the left channel has a whopping 41.5V (V, not mV) . I noticed some previous "repairs" in here, including this weird double resistor arrangement to replace an driver emitter resistor (circled in yellow) that had blown a crater in the board. This amp features push-on connectors for all the boards, and pulling the connection off for the left channel speaker output to the protection circuit gives the green LED and the relay clicks on.
The output transistors on the right channel are Hitachi 2SA753 and 2SC1343 pairs, which is what the service manual says they should be, but on the left channel are Toshiba 2SB556 and 2SC1079. Pulling and testing these, the 556 is open circuit from the Base to the Emitter. When I searched through the archives, I couldn't find much replacement info looking for the 2SA753, but searching for the 2SC1343 came up with OnSemi MJ15024G and MJ15025G used in a Marantz amp, that thread is here. Would these be suitable for this Optonica amp as well?
Lee.
Lee.
