RE: Unicorn Pepper Mills, by Tom David, Inc
http://www.unicornmills.com/
Of all of the Pepper Mills I have owned over the years My Unicorn 9" Magnum is the best of the best. I have never had a mill that once set, stays set and you get a consistent grind every single time, plus you know, every single time, how much cracked pepper it is going to produce with each twist of the grinder. The Unicorn Mills are made in Nantucket, Massachusetts, with the mill elements made in Italy, the best. They can custom make them for you. If you use white pepper they can assemble the their pepper mills with a black body and a white top so you can easily tell the difference when you are cooking. I have finally ordered their Salt Mill.
The 9" Magnum Pepper Mill
They don't make the Salt Mill in the 9" Magnum size. so I purchased the 6" Key Top Mill. Unicorn salt mills have proper ceramic grinding elements that will not corrode. My final Peugeot salt mill with it's stainless steel grinder finally died. I was ordering some more salt from Salt Works and I decided it was time to replace the worn out Peugeot.
https://www.seasalt.com/ Be sure to check out their bulk section you will save big bucks.
6" Key Top Salt Mill
